Uploaded emoji images appear to be getting cropped
(PJH) #1
Continuing the discussion from Changing emoji size:
Uploading images that aren’t square seem to get mutilated.
Original:
After upload:
Emojis from animated gif are shown uglily
(Régis Hanol) #2
We automatically resize emojis to make sure they stay small. Might not be the right defaults?
https://github.com/discourse/discourse/blob/master/app/jobs/regular/resize_emoji.rb#L10
(PJH) #3
Can you make a check on the image and only resize if it exceeds (configurable?) limits?
For instance that line is doing the exact opposite of what you intended with my image:
Original: 4.42K
Your ‘optimized’ image: 39.73K
You’ve basically made the image 10 times larger than it was, while breaking what it represents :frowning:
(Régis Hanol) #4
:100:% fail
:walking: -> :door:
(Régis Hanol) #5
Thanks for reporting that @PJH. That issue is now fixed :snowman:
https://github.com/discourse/discourse/commit/82157418eb00c57cc12c123b23f8baa324796745
(Jeff Atwood) #7
I just want to clarify @pjh that only square, emoji sized images are supported here.
If you are putting in banners or other large non-square images… that’s outside of the spec of Emoji.
@zogstrip just to confirm, we should enforce this. Emoji means a very specific thing. If people want to add something outside of that, it should be a plugin.
(Régis Hanol) #8
We’re only inforcing the “square” rule via CSS which can easily be overrided via custom CSS.
(Jeff Atwood) #9
We should be enforcing it on the files as well. Emoji are not irregularly sized… none of them are. They’re square.
http://www.unicode.org/reports/tr51/tr51-1.html#Identification
Current practice is for emoji to have a square aspect ratio, deriving from their origin in Japanese. For interoperability, it is recommended that this practice be continued with current and future emoji.
Non-square “emoji” cannot be allowed.
(Régis Hanol) #11
Just added a new site setting: enforce_square_emoji that is enabled by default.
(oops, seems like my quotes were removed from the commit message :cry:)
#12
I have a similar issue but with square aspect animated gif:
This gif:
http://hub.unitedwestand.fr/uploads/default/_emoji/trollface2.gif
Is shown like this :
http://hub.unitedwestand.fr/uploads/default/_emoji/trollface2.gif?v=0
The gif seems ti be correctly uploaded but not correctly shown with this “?v=0” at the end of the link.
Are animated gif supported as emoji ?
(Régis Hanol) #13
