URL causing multiple 429 onebox errors
(Joshua Rosenfeld) #1
Putting this in support - it’s by no means fatal, as the URL should not onebox anyway. I noticed when I attempted to add the following link to a topic it attempted to onebox far longer than normal. I eventually opened the console and noticed numerous 429 errors had occurred.
Here’s the URL: HTML Standard
Screenshot of console:
Link to post with URL
(Jeff Atwood) #2
One for @zogstrip to look at
(Jeff Atwood) #5
This is a problem with the bad IPV6 route to this site, specifically.
