Url wildcard match in PluginAPI
(Joe) #1
How can I use a wildcard for url pattern matching onPageChange?
I’m trying to fire a script on all category pages and here’s what I have
api.onPageChange(url => {
	if (url === "/" || url === "/latest" || url === "/top") {
		foo();
This works well and fires as expected. However, I would like to add category pages as well but don’t want to specify a category url.
Something like this
url === "/c/*"
to match any category page.
So how can I fix this:
	if (url === "/" || url === "/latest" || url === "/top" || url === "/c/*" ) {
		foo();
:sweat_smile:
(Vinoth Kannan) #2
You can use JavaScript RegEx match method like below
if (url === "/" || url === "/latest" || url === "/top" || url.match(^\/c\/) ) {
  foo();
https://regex101.com/r/n0Xe6E/1
(Joe) #3
Thank you so much :sunflower: @vinothkannans that’s a wonderful resource.
You’re right ^\/c\/ matches correctly in the tool.
But I get a syntax error when trying to add it like so:
		foo();
Trying it without resolves the error like so:
if (url === "/" || url === "/latest" || url === "/top" ) {
		foo();
I tried to play around with it without luck :upside_down_face:
Thanks again :ok_hand:
(Vinoth Kannan) #4
Oops. I missed the wrapping slashes / in the above code. It should be url.match(/^\/c\//)
(Joe) #5
Amazing :smile::fire:
That worked like magic! :+1:
