User card popup offset problem with custom header
(TheLoneCuber) #1
I noted a problem with user profile pop-ups on 1.1.0.beta7 here, and since the same problem exists on How To Geek’s Discourse I’m guessing it will effect most users running 1.1.0.beta7 with a custom header.
Adding height to the header (by way of image or other: on standard header only, not mobile) offsets the user profile pop-ups by the new height amount. In my case the header image is 400px high, so the user profile pop-ups pop up 400px below the user profile, which means it actually appear off-screen on smaller viewports.
I’ve only added the header image to my Discourse after upgrading to 1.1.0.beta7, so I’m not sure if this is a known problem, though I’ve not found any other posts on it. And I hadn’t noticed it on How To Geek’s Discourse instance previously either.
You can see the problem live by clicking any user profile thumbnail at http://discuss.howtogeek.com/.
Please visit our Discourse Forum! (Directory)
(Jeff Atwood) #2
Yep I have seen this on htg for a while, not sure what the fix is.
(ForgotPants) #3
Has there been any update on fixing this?
(Jeff Atwood) #4
I thought @sam tweaked this for HTG at one point?
(Jeff Atwood) #5
Still an issue on Turtle Rock as well as other places.
(Daniel) #6
Any update on a fix or a temporary work around?
(Jeff Atwood) #7
Do we still see this on Turtle Rock @neil?
(Neil Lalonde) #8
Looks like the same offset to me.
(Jeff Atwood) #9
