User fields issues (preventing signup)
(James Milligan) #1
I note that this was in a recent commit, so it’s more than likely that this has just not been finished, rather than a bug.
On latest pull from the repo, I added a user field via Customise, a standard text field with “Membership Number” in, and set it to “not editable” after signup.
Going to the signup page shows the usual form (username/password etc), but no box for a field. Trying to register fails, see screenshot below.
The field also doesn’t show on a user’s profile at all, although when set to be editable, is so via preferences.
Inconsistencies on "User Fields" admin interface
(Jeff Atwood) #2
Did you scroll down? There was a giant <h3> there that I severely objected to and removed.
(Robin Ward) #3
Can you confirm that you refreshed your browser after you added the field? I suspect that the window you tried to create the account in was not refreshed.
(James Milligan) #4
Yep definitely refreshed, just tried on mobile.
I’ve got the fix you popped on earlier @jeff but no luck getting it to display the field.
(Robin Ward) #5
Any way you’d let me take a look at the instance? I am out of ideas and it should be working.
(James Milligan) #6
Not at the moment unfortunately, but I’ve replicated it on a local VM running a Docker install. It appears ‘login required’ is the setting that removes the field from the signup page. Toggling it off shows the field, and vice versa.
(Robin Ward) #7
Awesome, that’s all I needed. A fix is coming soon.
(James Milligan) #8
Great, looks like your commit below fixed the issue. Cheers @eviltrout :thumbsup:
https://github.com/discourse/discourse/commit/381814fd5dd45ba0f92a4ffc1c5d6991918af04f
(Jeff Atwood) #9
