User Listing Timing out
The user listing (Not admin view) is timing out for some reason. I attached a screenshot of the behavior.
I removed any custom SQL related to badges I thought that might be related, but still exhibiting this behavior.
Any thoughts?
Also to be clear it’s hostname.com/u/
Screenshot
Hello,
can you look at the browser console please?
This seems to be the bottle neck: https://hostname/directory_items?period=weekly&order=likes_received
Also the console prints:
decorateCooked should be supplied with an id option to avoid memory leaks.
U @ _application-214645bb36395662c83353060d23e8f4b5da276a6dc424246d4aba6685dea9ea.js:22245
This is the code snippet that’s causing issues.
 function applyAttributeBindings(element, attributeBindings, component, operations) {
    var seen = [];
    var i = attributeBindings.length - 1;
    while (i !== -1) {
      var binding = attributeBindings[i];
      var parsed = AttributeBinding.parse(binding);
      var attribute = parsed[1];
      if (seen.indexOf(attribute) === -1) {
        seen.push(attribute);
         AttributeBinding.install(element, component, parsed, operations);
  i--;
Value of I from the console in screenshot attached.
as you can see the value of i is completely invalid, so not sure what is going on but it’s not a counter anymore. the i !== -1 is true so it never finishes. (I used the wrong check in the screenshot but i != -1 and i !== -1 are both returning true)
Any updates on this? Anything else I can provide to help debug the issue?
We are at our yearly world meetup for this week, so asking next week might work a bit better :wink:
I see someone added the solution plugin. That’s awesome. :slight_smile:
Noted, I’ll check in later and hopefully someone can shed some insight on what is going on. Thanks.
