Usercard does not resize for obnoxiously large images
(Kane York) #1
← click over there, see for yourself
image for history: link
(by the way, the punchline is here)
(Jeff Atwood) #2
I don’t know if there’s any sane way to handle that – just specify a max-height and max-width for the <img> tag in the usercard?
Not sure it’s worth it versus the “please don’t do that”, and “if you keep doing that, there will be consequences” non-technical solution.
Overall: meh.
(Kane York) #3
That’s fine with me. I think I’ll be removing it soon, because it also makes the “View Profile” and “Send PM” buttons really hard to press.
(Sam Saffron) #4
I don’t see the point of allowing images on the usercard and disallowing them in the profile, it just feels arbitrary / wrong.
We should scrub the profile so it looks the same in both spots
(Jeff Atwood) #5
Agree, @eviltrout can you make sure the usercard is using the same logic as the user page in displaying profile info?
(Sam Saffron) #6
I think this is on @zogstrip’s plate, images + text should be capped at a fixed height.
(Régis Hanol) #7
I fixed it a couple of days ago but added some more CSS to better handle images
https://github.com/discourse/discourse/commit/18f5751f3fa3d93ef95b0d6df7f05ea8089600ea
(Régis Hanol) #8
This topic was automatically closed after 12 hours. New replies are no longer allowed.
