Username change implications
admin
(Sebastian) #1
Haven’t quite found the answer anywhere, so forgive this question which I am sure must have been asked before. If I (being the admin) change someone’s username (which I can and for which real life scenarios exist that might ask for this), what are the implications? I am asking specifically about @ mentions and quotes within the forum as well as links. Do I break a lot of legacy content with a username change or is it being kept internally and it’s all forwarded? How is Discourse handling this? Thanks in advance!
(Jeff Atwood) #2
Old posts with mentions and quotes will have the wrong name embedded, that is about it.
(Sebastian) #3
So they show the wrong name, but will they remain linked correctly?
(Ionuț Staicu) #4
Also check out this topic:
(Sebastian) #5
I’m on a hosted Discourse, so that’s not even an option, but I’ll keep that link in mind
(Jeff Atwood) #6
Be aware that as @eriko noted, changing username will effectively wipe the post / topic history on your user page, though:
