Users are not able to signup on Safari browser for iOS
(Christopher) #1
I just installed discourse on digitalocean so it’s a fresh install. I’ve tested the signup modal on iPhone & iPad with Safari. It just hangs there when I use Safari. If I use iOS Chrome it works.
I don’t have any plugins so far.
Thanks for any help!
(Jeff Atwood) #2
Unless you can repro this problem here on meta, this is something about your setup. Did you deviate from any of the defaults or install any plugins?
(Christopher) #3
Hello @codinghorror thanks for the reply. I can reproduce it on this meta discourse board. I signed up as dragonfire1119test and it’s stuck on the creation modal. I’m using a iPhone with Safari.
It’s got to be something with the frontend code.
It’s not throwing any console errors. Just gettng stuck…
When you get stuck with the create modal on safari you can’t do anything else so you have to create a new tab.
#4
No repro I just created this account here on meta through my iPhone on Mobile Safari with zero issues.
(Christopher) #5
Hello my iPhone is running iOS 10 & Safari.
This is what I get when I register on my iPhone. It locks the tab up & I have to close it. Same thing on a iPad.
Thanks
(Jeff Atwood) #6
Sorry, I cannot repro this on iPad or iPhone.
(Sam Saffron) #7
Do you have cookies disabled somehow?
(Wes Osborn) #8
Do you have any Content Blockers enabled (Settings -> Safari -> Content Blockers)?
