Users being asked to verify e-mail after upgrade AND domain change
(Magnetidog) #1
Hello everybody.
So, we recently (yesterday) upgraded to the latest version, and some users are getting the following message when logging into the forum:
You can’t log in yet. We previously sent an activation email to you at useremail@xxxxx.com. Please follow the instructions in that email to activate your account. Click here to send the activation email again.
Is there anything I can look into to determine why this is being triggered? The users show as “Active” in the backend and I do not see anything weird or unusual in their profile.
I did not add/remove plugins during the upgrade.
Thanks!!!
(Magnetidog) #2
We did the upgrade, on a note, after we moved to a new domain. I am not sure if the two things could have triggered this whole thing.
Looking at the DB entries for the user via psql, all looks in fine the database.
(Magnetidog) #3
Adding a further exploration in here in case somebody is having the same issue.
So far it looks like that if I remove the user.email_confirmed check in line 207 of the session_controller (yeah, I do not recommend you do that)
(user.active && user.email_confirmed?) ? login(user) : not_activated(user)
Then the error message is not shown. I am trying to go backwards to figure out how email_confirmed is determines, as if I just look at the database, all looks fine: the users are active.
(Kane York) #4
email_confirmed? checks if they have a activation email - did something happen to the email logs table?
(Magnetidog) #5
Hi @riking - yeah, they had the activation email, but I just found out the cause. I think it is a thing that might happen also to others in the future, and not so obvious at first. It took me so long it is ridiculous; but at least I now know a bit better Discouse’s session auth.
When I moved the domain, I did a remap of the domain in Discourse following the guide, from old domain.com to new domain.com, and many of these users were using the olddomain.com in their e-mail!
It looks like the rewrite changed all their domains ONLY in the “email_tokens” tables; so when Discourse did a table join between the user table and the email_tokens to verify if the user had been verified, it turned out as false. I fixed it by going via shell and doing a search and replace on the table.
All good now!
