Users cannot edit their username
no option to edit username
Hi team,
My users have lost the ability to edit their usernames. Can you investigate?
Thanks,
Emma
What’s the value of username change period? (The number of days after registration that accounts can change their username (0 to disallow username change).
And you’re not using SSO, right?
not using SSO-correct… it’s currently set to 3 days
is the person trying to change their name been a member for more than 3 days?
yes, we have tested with 2 people who have both been members more than 3 days
If they have been members for more than 3 days and username change period is 3 days, the expected behavior is that they will not be able to change their username.
Perhaps you want to change that site setting to a bigger number.
a user who joined on Dec 4 is not able to. Could this be a bug?
If the username change period is set to 3, then no, this is not a bug. December 4 is more than 3 days ago, outside of the change period. As such, they should not be able to change their name.
We’ve adjusted the wording here as the description has tripped up people before.
The description for username_change_period is now “The maximum number of days after registration that accounts can change their username (0 to disallow username change).”
ok any recommendations on how we should adjust it then? I would like to allow my users to edit their usernames indefinitely.
Just set it to a high number, like 100000. That’s 273-ish years, far longer than you users will be using Discourse.
You understand that they’ll lose the connections to their existing posts?
Yeah they are ok with it.
Thanks,
Emma
