Using a root / apex domain with discourse [solved]
Hello,
Is it possible to use a full domain as the URL instead of a subdomain? For example, instead of chat.example.com, just example.com ? Also, if I’ve already set the subdomain, am I able to change it to point to the new domain that I just purchased?
Thank you.
Edit: Solution found here: Configure your hosted domain name at the root (example.com)
Ok, so I just created a new one, and will cancel/delete the other one.
What should the CNAME record look like? Right now it is
host: www
value: example.hosted-by-discourse.com
Edit: I just found this: Configure your hosted domain name at the root (example.com). Doesn’t look good :confused:
Yes, that’s called a root or apex domain, and it requires special DNS support per that topic.
I got it working, should have updated. Thank you for providing Discourse, it’s amazing!
