Using an existing Laravel Users DB
(Vinlock) #1
Hello,
I was wondering if I am able to use an existing Laravel Users DB with discourse.
Thanks!
(Joshua Rosenfeld) #2
I very strongly doubt it. Discourse uses a PostgreSQL.
(cpradio) #3
Well, technically you can if you can implement SSO.
(Mittineague) #4
I don’t know what is meant by a “Laravel Users DB”
I have not used Laravel, but AFAIK it’s a PHP framework.
It has its own database ??
From the docs
https://laravel.com/docs/5.0/database
Currently Laravel supports four database systems: MySQL, Postgres, SQLite, and SQL Server.
I also don’t know what the desired “use with” is.
If it is using Laravel to write PHP to work with the Discourse Postgres database, (as in “I don’t know Ruby / Ember” and want to use PHP") I guess it could be possible.
If it means “use Laravel to run Discourse” I guess that too could be possible given the time ambition and resources to replicate the Core code into PHP
