Using base image without nginx
Anyone running a minimal discourse base image without nginx? I already have an nginx setup for my server that is dockerized.
That’s not recommended. nginx within our base image does lots of useful stuff. You will be in a world of pain if you don’t use it. Instead, follow the instructions in Running other websites on the same machine as Discourse if you want to use a different nginx instance as a revers proxy for Discourse.
