Using camo with discourse?
(@SenpaiMass) #1
Hello,
Is there any possible way to link/use
GitHub - atmos/camo: an http proxy to route images through SSL with Discourse so the SSL page doesn’t break due to insecure images?
Edit: GitHub - ankane/camo: Ruby client for Camo - the SSL image proxy
Looking forward to a reply.
Thanks and regards.
(Sam Saffron) #2
We already take care of a lot of this by downloading local copies of images, do you have specific examples where this is not working?
(@SenpaiMass) #3
Thank you for your reply,
The remote images are downloaded properly and i have no issues with it, i just wanted to know if i disable the remote download feature , is there any way i could use camo with discourse?
Regards.
(Gerhard Schlager) #4
It doesn’t work with oneboxes. :wink:
But I’m quite sure camo won’t solve that either…
