/usr/bin/docker: Error response from daemon:
(Driver Geo) #1
Hello,
i have this forum for about one month and last night i made a server update and upgrade and after that my forum refused to start.
The error is :
`/usr/bin/docker: Error response from daemon: driver failed programming external connectivity on endpoint app (5cbf7e79f e9d7e1a9e5f45634355c0f439c9c2a05cab450094f174e1b06b1d27): Error starting userland proxy: listen tcp 0.0.0.0:80: listen: address already in use.
I`m a beginner at linux commands so please have patience with me.
I tried to reboot / turn off my droplet (digitalocean). I did a rebuild and still nothing.
If this helps :
root@gaming-club:/var/discourse# netstat -tulpn | grep :80
tcp6       0      0 :::80                   :::*                    LISTEN      1602/apache2
(Alexander Wright) #2
It looks like you have a webserver running on the droplet in addition to docker.
Try:
service apache2 stop
You’ll then need to disable it, but I’m afraid I can’t remember the command off the top of my head.
(Driver Geo) #3
The command is ok, the service is stopped. Now i turn it back on?
Or i do a rebuild app again and this also starts the apache2 server?
Edit: after i stopped apache2 server, in did a setup and Enter till the end. The setup was amde without errors.
Now forum is back online.
I still have a problem but this is not the right topic.
(Jay Pfaffman) #4
You should Uninstall apache.
