UTC - 4 in timestamps?
(Jefffrey) #1
Normally I get UTC + 2 (my timezone) timestamps for post. If I deactivate JS or look at the HTML source, what I see is UTC - 4 instead. Is this intentional? If so, why?
(Michael Downey) #2
Where do you see actual time stamps on Discourse? Everything I see is relative (e.g., 1d, 2w, 1 January).
(Jefffrey) #3
You see the local timestamp by clicking on the relative one. The timestamp I’m referring to can be seen by disabling JS.
(Michael Downey) #4
Oh, hmm. I’d never noticed that undocumented feature. :wink:
Is your server UTC-4 by any chance?
(Jeff Atwood) #5
@eviltrout can you confirm what time zone is used for the js off content we serve to Google?
(Robin Ward) #6
It looks like UTC-4. When you view the source you see they’re in this format: 2014-10-23T22:15:40-04:00 – I believe the -4:00 indicates that.
(Michael Brown) #7
Really, it should be UTC. All the timestamps should be UTC - it’s just easier that way.
But there’s nothing wrong with 2014-10-23T22:15:40-04:00 - it’s an ISO 8601-compliant timestamp.
(Dean Taylor) #8
(Jeff Atwood) #9
I just wonder where that specific time zone offset comes from @eviltrout?
(Robin Ward) #10
It’s set here, in our application configuration:
Regardless, rails stores the date in UTC in the database and just uses that setting for formatting. It also has support for user-selectable time zones, we just don’t have that in Discourse yet.
(Jeff Atwood) #11
We should change that to UTC, on that line.
(Robin Ward) #12
Sure, but just so we’re clear, the timestamps included the offset so any date parser would have known the UTC anyways:
(Jeff Atwood) #13
