Vagrant setup questions
(Del Boy Trotter) #1
Hi, just a general question about Discourses Vagrant setup:
I can see in the Vagrant script that Discourse pulls an image with Redis, Postgre, Node, Ember etc all pre-installed.
Why then is Chef also being used to add apt, build-essential etc after the point?
Is there a reason for this?
(Del Boy Trotter) #2
To add to this, how does Discourse install ember-cli into that box? I am trying to automate this and keep hitting all manner of issues. Is this part done manually before packaging and uploading the box?
(Kane York) #3
The Vagrant box definitely needs to be recreated. I’m doing my dev on my machine outside a VM.
I keep postgresql and redis-server in systemd as disabled, with a script to start both of them.
$ cat ~/projects/discourse/update.sh
bundle install
# nb: pkexec is graphical sudo
pkexec systemctl start postgresql redis-server
bundle exec rake db:migrate
RAILS_ENV=test bundle exec rake db:migrate
(Del Boy Trotter) #4
So ember-cli and all of it’s dependencies are installed into the Ubuntu box before packaging as a vagrant box and being uploaded so it can be used as base?
config.vm.box = 'discourse-0.9.9.13'
config.vm.box_url = "https://d3fvb7b7auiut8.cloudfront.net/discourse-0.9.9.13.box"
I seem to be OK getting things like postgresql installed but getting ember-cli setup through the script provisioner is causing me no end of issues
