Vagrantfile @ discourse_docker
(Frans Thamura) #1
I found a Vagrantfile in discourse_docker
I try to run it, it is a ubuntu image that install docker…
any ide to setup discourse inside this ?
I found also git is not default added inside this Vagrantfile.
is there any way to install using this ?
(Matt Palmer) #2
That Vagrantfile is designed for testing changes to the discourse_docker repo only. It is not intended for use in getting a production-like install up and running. There are instructions in the repo README.md “Developing with Vagrant” section that describes how it is intended to be used.
