/var/discourse just vanished
(cat24max) #1
Hey guys,
I was trying to change the hostname of my installation, so I followed this tutorial.
Discourse was installed to the default /var/discourse directory.
After using the “./launcher enter app” command I was switched from /var/discourse to /var/www/discourse and followed the next steps.
Now as that still didn’t fix my broken CSS and pictures, I tried to go back to the /var/discourse folder, but it just isn’t there anymore. How can this happen? I cannot find a file called “app.yml” ANYWHERE on the hard drive.
(Andrew Waugh) #2
./launcher enter app takes you into the docker container that is doing all the magic. /var/discourse is “Above” you. If you type “exit” you will exit from the shell inside the container, and you will be back in /var/discourse
(cat24max) #3
Oh thanks - well that explains everything :smiley:
(cat24max) #4
Still, my site doesn’t work…
https://domain/style.css will not load the CSS file but just throw a Discourse 404, hence destroying the style…
(Andrew Waugh) #5
Are you using admin/customize/themes to get to and edit your .css?
(cat24max) #6
I did to add Piwik to it…
(Andrew Waugh) #7
I’m not following you w.r.t. piwik.
.css et al are not my forte, so I’ll let someone else jump in and help.
(cat24max) #8
(Andrew Waugh) #9
Aha…
I had something similar to this a while back. The '80s style page was because of a bad plugin. Perhaps your problem isn’t .css at all.
What plugins do you have installed? (They’re listed in app.yml, near the bottom)
(cat24max) #10
No plugins, just a plain install…
(Andrew Waugh) #11
Besser so?
goto your site and add “/safe-mode” at the end, that will help you narrow it down. (given the size of the “26” without safemode, I think your .css is bent, if not broken.
(cat24max) #12
Well, but why would that be? I mean the style.css is not even loading, seems like a rewrite problem…
(Andrew Waugh) #13
Sorry, your question is above my pay grade, but the fact that Search results for ‘style.css’ - Discourse Meta only shows 3 hits, one of them yours makes me think you’re trying to do something in a non standard way.
(Felix Freiberger) #14
This sounds like a potential source of trouble. What did you do, exactly?
