View-counts and Jekyll comments
#1
I’ve added Discourse comments to my Jekyll site. Everything seems to be working great!
I did have one question though about how views contribute to the view count in Discourse: i.e., if I have Discourse comments on each post I make on my site, can the Views column in Discourse be considered a (highball) measure of the actual page views of a particular post?
(Sam Saffron) #2
I think yes, but I would go with google analytics here.
Your google login appears to be broken due to mismatching domains.
#3
Thanks! I do have Google Analytics set up; was curious as to what Discourse actually measures from the comments on a static page. That’s good to know.
Thanks for letting me know! I checked my setup via the how-to and everything appears to be in line.
Do you know if running Discourse through CloudFlare would affect authentication?
#4
Should be working now. If you don’t mind, could you confirm on your end?
If helps someone, I had an incomplete redirect on the URL (perhaps it changed?) and then needed to set an email address.
Thanks again!
