Visiting from Admin Logged in account gives Error 502
(Veer) #1
The forum works verfy fine, browsing logged , but if i brwose the forum from a admin logged in account, it gives Error 502.
Already rebuilded the app many times.
(Arpit Jalan) #2
Are you seeing any errors in /logs? If yes, what does the error message say?
(Veer) #3
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/logster-1.2.7/lib/logster/logger.rb:93:in `add_with_opts'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/logster-1.2.7/lib/logster/logger.rb:50:in `add'
/usr/local/lib/ruby/2.3.0/logger.rb:498:in `warn'
config/unicorn.conf.rb:129:in `check_sidekiq_heartbeat'
config/unicorn.conf.rb:146:in `master_sleep'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.2.0/lib/unicorn/http_server.rb:284:in `join'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.2.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/bin/unicorn:22:in `load'
/var/www/discourse/vendor/bundle/ruby/2.3.0/bin/unicorn:22:in `<main>'
(Veer) #4
anybody please help.
(Arpit Jalan) #5
The error log you provided is not relevant to the error you are seeing.
You will need to give us exact repro steps as I am unable to repro this error. Try commenting out all the plugins (if present) in app.yml file and rebuild again.
