Webmail not working after setting up discourse
(Nnamso Anthony) #1
After I changed my DNS to Digital Ocean I have noticed that my webmail has not been working.
I have discourse installed here
Normally I am supposed to access my mail like this
http://mytestimony.com.ng/webmail
Please, How do I fix this?
Or what is the other way around it?
I am using mailgun.
(Robby O'Connor) #2
What is the issue? What is webmail in this context? Are messages not sending? What’s in the logs? Check mailgun’s logs as well to see what’s happening.
(Nnamso Anthony) #3
The issue is that I can’t receive emails via my webmail. example info[at]mytestimony[dot]com
(Robby O'Connor) #4
You didn’t answer the other questions…what is in your logs…are your pop3 settings correct?
(Nnamso Anthony) #5
Date/Time Summary
06/05/17 02:58 AM Delivered: noreply@share.mytestimony.com.ngnnamsoanthony@gmail.com ‘[My Testimony] Site Backup Download’ Server response: 250 OK
06/05/17 02:58 AM Accepted: noreply@share.mytestimony.com.ngnnamsoanthony@gmail.com ‘[My Testimony] Site Backup Download’
06/04/17 11:02 PM Delivered: noreply@share.mytestimony.com.ngnnamsoanthony@gmail.com ‘[My Testimony] Site Backup Download’ Server response: 250 OK
06/04/17 11:02 PM Accepted: noreply@share.mytestimony.com.ngnnamsoanthony@gmail.com ‘[My Testimony] Site Backup Download’
06/04/17 05:37 PM Delivered: noreply@share.mytestimony.com.ngnnamsookuku@gmail.com ‘[My Testimony] Confirm your new account’ Server response: 250 OK
06/04/17 05:37 PM Accepted: noreply@share.mytestimony.com.ngnnamsookuku@gmail.com ‘[My Testimony] Confirm your new account’
(Robby O'Connor) #6
Okay nothing there…
Are you setting up reply by email? A tip when asking for help on forums to avoid the need for 20 questions: be as clear as humanly possible – you’re not clear at all. Discourse isn’t for webmail, it’s a forum. Why are you calling it webmail?
Consider using the mail-receiever container – it’s freakishly easy to set up:
(Robby O'Connor) #7
This is not publicly accessible.
(Jay Pfaffman) #8
You installed Discourse on that domain and Discourse does not handle webmail. The simplest solution is to install Discourse on another domain like community.mytestimony.com.ng and put whatever used to handle your webmail back there.
It’s conceivably possible to have that URL still handle your webmail (anything is possible),but it will be much more complicated.
Fixing your webmail is not really a Discourse problem.
(Robby O'Connor) #9
Yeah, I’d recommend installing discourse on its own server.
