Welcome letter doesn't come anymore, where should I enable it?
(Jiamin Zhu) #1
I changed some build-in template of the welcome letter (the user get when newly registered) but later on I found that new user no longer get any welcome letter. Is it because of the template gets modified? Could you help me to get the welcome letter back?
(Dean Taylor) #2
You might have just switched the option off - check settings for the send welcome message option:
Otherwise check the /logs page for any errors.
(Jiamin Zhu) #3
I actually turned it on but still there is no welcome message. There was
but after I change some template text, they is just no more. Anyway to
track the problem down?
(Jeff Atwood) #4
Is there anything in /logs that looks related, when you visit that URL in your web browser while logged in as admin?
(Jiamin Zhu) #5
ah. I checked the log but didn’t see anything related…
Not 100% sure though…
