What are the queued-posts and translation keys
translation
(Ilya Kuchaev) #1
Hi there,
What are the queued-posts URL and correspondent translation keys.
Can’t find them in Transifex.
(Robin Ward) #2
I just merged this into master yesterday. The new feature supports moderators approving/rejecting posts in a queue.
I suspect Transifex hasn’t been updated with the new keys yet as it was merged so recently. Is that right @techAPJ?
(Arpit Jalan) #3
Source files in Transifex was last updated on Tuesday.
I just pushed the source files again, so translators can translate the new keys.
(Ilya Kuchaev) #4
I believe that the menu item should be disabled once pre-moderation is disabled.
(Robin Ward) #5
Hmmm, the problem is other things like Akismet will be using the queue. It would have to know that there’s no possible way to enqueue posts.
(Sam Saffron) #6
We should definitely address this since the general digital ocean installs out there will not have akismet or post enqueuing. We should also ensure that it hides itself if akismet is installed and disabled via site settings.
(Robin Ward) #7
Good point, I’ll figure some way to avoid displaying it.
(Robin Ward) #8
Update: The Needs Approval menu item only shows up if configured or extended via plugin:
https://github.com/discourse/discourse/commit/26693c16ac1f3362a8305bba7db72beb9db4d45a
