What command line delete backup file?
Hello admin Discourse,
My website get error: 502 Bad Gateway and get notification when rebuild app:
You have less than 5GB of free space on the disk where /var/lib/docker is located. You will need more space to continue
Now, i wanna delete Backups file on Dashboad, can we delete them in Zoc7?
what command line can i do it?
Thank you!
I don’t know what a zoc7 is.
rm /var/discourse/shared/standalone/backups/default/*
If you hit the tab key 3 times you can use tab completion to select just a few.
