What does "dismiss" do exactly? Need for translation purposes
(Anton) #1
So, may someone explain exact meaning of the “Dismiss” button? I strive to find the best translation.
Is dismissing a temporary or forever action? Will the dismissed notification ever become active again?
P.S. Translating/reviewing strings with the keys that start with js.topics.bulk.
(Sam Saffron) #2
Hmm… the string is “Dismiss…” when you click it you get to choose if you dismiss it temporarily or forever.
(Hugo Roger) #3
What are you translating it to?
(Mittineague) #4
Maybe using a thesaurus would be helpful?
http://www.thesaurus.com/browse/dismiss
(Anton) #5
Russian and Ukrainian.
Okay, so what will dismiss do? Will it just mark all unread as read?
Also, how is it different to “Reset Unread”? js.topics.bulk.reset_read
It might be that the latter one is not actually in use anywhere?
