What does rake uploads:migrate_from_s3 exactly do?
It seems to me it is only migrating images from s3 to local. Am I right? In my case, there was a zip and mp4 file that remained on s3. I’m using minio according to this:
https://meta.discourse.org/t/setting-up-backup-and-image-uploads-to-minio-s3/95123
Yes you are correct, if there are any images that were not correctly migrated from s3 and you have a repro it is bug we want fixed.
Thank you very much for your reply.
Can you tell me why its designed like this? why other things like audio and video shouldn’t be migrated?
Sorry, there is a communication breakdown. I never said this.
If zip/mp3 not copied to local AND you can repro… there is a bug with the task.
In other words, it is meant to copy EVERY SINGLE upload from the cloud to local.
I think I have repro it already. How can I give you more information?
I explained the problem here:
