What does "send digest label" do?
(Hosein Naseri) #1
There is a section called “send digest label” in preview digest page, and it takes an email. What does it do? when I press send button, It gives internal error.
Preview-digest error
(Vinoth Kannan) #2
It shouldn’t display as “send digest label”. Instead it should display as “Send this result to:”. Also by pressing send button it will send you test message with preview digest generated.
May be something wrong in your installation. So upgrade to the latest version and try again.
(Hosein Naseri) #3
Yes you’re right. I was referring to its site text label because I’m using another translation for discourse.
So I have Upgraded discourse to latest version. I put my email into that textbox and press send. But I get the following message:
500 Internal Server Error
Is it a bug?
(Vinoth Kannan) #4
It may not be a bug. Check the log messages in /logs URL. It can tell more details about the problem.
(Hosein Naseri) #5
Yes. It turns out that I need to also input the last time seen textbox and refresh the digest preview, before I click send button.
