What html tags and styling can be used in posts?
(Zoltan Szathmary) #1
Is there a way to know or see a well gathered info about what hmtl tags and styling can be used when writing a post?
For example, I know that H1 header works. But if I want to set a different color to it with style=“color:red;”, that won’t work.
Is there a list where I can see what works and what not?
Thanks in advance
Z.Sz.
#2
This may not directly answer your question but I believe you’ll find most of these answers by simply searching these forums as well as searching the markup language Discourse utilizes.
# This would be H1
## This would be H2
### This would be H3
*Italics*
**Bold**
As far as color styling, that is not inherently supported. However, you can get a plugin that does just what you’re looking for. Now I was going to link you the bb color code plugin we’re using but that doesn’t appear to be available (as a topic) on here anymore. So I’d say, check out this newer bb codes plugin. That would look like as follows:
[color=Hex/Dec/CommonName]TEXT[/color]
I usually quickly pull up this list of web safe colors and use the chart at the top.
P.S. - Generally the ideology of Discourse is ‘keep it clean and simple’, which I like. However, there are times where you’re looking for added functionality not provided. This is where plugins come in handy. Therefore, I’d recommend you check out what plugins are available. If a plugin doesn’t exist for something you’d like, you could even ask if someone is willing to invest time into making it possible.
(Zainab) #3
Hi,
You can use HTML tags paragraph, links, header, image, lists ect.
CSS style="" not supported
(Zainab) #4
This doesn’t work for me :frowning: even on this site
#5
So no, what you quoted won’t work on this site. They do not use a bb color code plugin.
(Zainab) #6
Oh I thought was in built. Thanks
I guess I didn’t read it in full just jumped in
#7
It happens. We all overlook things from time to time, especially when in a hurry. :runner:
(Zoltan Szathmary) #8
Thanks for the ideas, we’ll definitely look at these plugins in the near future!
#9
I’ll just add these two links here.
http://commonmark.org/help
http://www.bbcode.org/reference.php
(credits to codinghorror who posted this elsewhere)
(Zoltan Szathmary) #10
Sern10h
Markdown Reference
BBCode tags reference
Thanks, these are really helpful too!
