What's the correct way to reset instance?
#1
Hi, first post here, I’m new to discourse.
I wanted to reset my installation completely so tried
./launcher stop sd2016
rm -rf /var/discourse
./launcher bootstrap sd2016
./launcher start sd2016
It starts okay, but logs show nginx can’t write to its logfile - dir doesn’t exist so:
mkdir /var/discourse/shared/standalone/log/var-log/nginx
And all is fine. Is this a bug or is rm -rf /var/discourse the wrong way to go about resetting my instance?
Thanks
JH
(Sam Saffron) #2
this is a bit confusing… /var/discourse is meant to have the source of discourse docker, you don’t want to rm that. This indicates you checked out discourse to a custom location.
to reset everything I would …
cd /var/discourse
./launcher destroy app
rm -rf /var/discourse/shared
./launcher rebuild app
#3
Thanks Sam. Does that mean I have a broken installation - how should I go about repairing it? I assumed ./launcher would be self-healing with all the git-pulls!
(Jeff Atwood) #4
You can git pull it again as needed following the setup instructions.
#5
Ah - that explains the confusion … I’d done my initial git clone into my home directory so launcher was ~/discourse/launcher . That’ll be why I still had a launcher after removing /var/discourse . Thanks for your help!
