What's the path to Discourse installation and uploads directories?
(Aahan Krish) #1
I installed Discourse following the official documentation using Docker. Looked for /var/www/discourse, but it doesn’t exist.
So, what’s the actual location of Discourse (i.e. site’s root)? Where is the uploads directory located?
(Régis Hanol) #2
Discourse is installed in /var/www/discourse in the container. On the host, you have to go to /var/docker and then execute ./launcher ssh app to ssh into the container.
The uploads directory is located at /var/www/discourse/public/uploads (also inside the container).
(Aahan Krish) #3
@zogstrip Ah, so these directories in the container, aren’t they available via (S)FTP? i.e. don’t they have a real path where they can be accessed directly?
(Bill Ayakatubby) #4
See also:
(Régis Hanol) #5
Some of the files are shared with the host and are available at /var/docker/shared (on the host).
