# When exactly does Discourse Rewind become active for members? (self-hosted, plugin already enabled)
**URL:** <https://meta.discourse.org/t/when-exactly-does-discourse-rewind-become-active-for-members-self-hosted-plugin-already-enabled/417685>\
**Category:** Product Support\
**Tags:** rewind\
**Created:** [17 november 2026 om 20:51 UTC](https://meta.discourse.org/t/when-exactly-does-discourse-rewind-become-active-for-members-self-hosted-plugin-already-enabled/417685 "2026-11-17T20:51:40Z")\
**Posts on this page:** 1\
**Page:** 1
## AI-generated summary
[Orioni](/t/-/417685/1) inquires about the activation timeline for Discourse Rewind on a self-hosted instance where the plugin is already enabled. Despite confirming the plugin is active in `/admin/plugins`, they are unable to determine when the avatar animation and recap page (`/my/activity/rewind`) will become visible to members. This lack of clarity prevents them from effectively preparing their community for the year-end recap.
The user notes that both the plugin topic and the 2025 announcement state that enabling the plugin requires no further configuration. However, these documents do not specify whether the features appear immediately upon enablement, only after a specific date, or within a particular time window. Orioni raises four specific questions:
1. Is there an internal date or period check that gates visibility for the avatar animation and recap page? If so, what is the window (e.g., December to January)?
2. What time period does the recap summarize (e.g., calendar year-to-date, trailing 12 months)?
3. For a self-hosted site running `2026.11.0-latest.1` with the plugin enabled since setup, should members already be seeing the feature?
4. Are there logs, Sidekiq jobs, or site settings that admins can use to confirm the activation status rather than guessing?
Orioni mentions that the Discourse Helper bot previously misidentified the query as being about the *Yearly Review* plugin (which runs January 1–31) and incorrectly asserted that "enabled = active" means the feature must already be live. The user emphasizes that they do not see the feature themselves and seeks definitive information on how activation is triggered.
<div class="post-metadata">
**Author:** ![Orioni](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/orioni/32/542679_2.png) [@Orioni](https://meta.discourse.org/u/Orioni)\
**Post date:** [17 november 2026 om 20:51 UTC](https://meta.discourse.org/t/when-exactly-does-discourse-rewind-become-active-for-members-self-hosted-plugin-already-enabled/417685/1 "2026-11-17T20:51:41Z")
</div>
🙋 When exactly does Discourse Rewind become active for members?
I run a **self-hosted** Discourse site. Rewind is enabled at `/admin/plugins` and shows
as active, but I have no way of telling _when_ it will start appearing for my community
members. I’d like to prepare them in advance. A year-end recap invites questions,
and I’d rather not be surprised by them.
## Earlier research:
I couldn’t find a clear answer in the existing docs and announcement:
- The plugin topic ([Discourse Rewind](https://meta.discourse.org/t/discourse-rewind/390847)) and the [2025 announcement](https://meta.discourse.org/t/degauss-your-screens-discourse-rewind-2025-is-here/390852)
both say to _“visit `/admin/plugins` and enable the plugin, no other config necessary.”_
- The announcement mentions members will see _“this enticing little animation around their
avatar”_ once the site has the latest update. However, it doesn’t state whether the animation and the recap page activate immediately on enable, only after a specific date, or only within a particular window.
- There is no date/period setting in the admin UI, and the announcement thread
(which I read through in full) does not clarify this.
## My specific questions:
1. Is there a date or period check inside the Rewind service that gates when the avatar
animation and `/my/activity/rewind` become visible to members? If so, what’s the
window (e.g. December X – January Y)?
2. What time period does the recap summarise: calendar year to date, trailing 12 months,
or something else?
3. For a self-hosted site on `2026.11.0-latest.1` that has had the plugin enabled since
setup, is the expectation that members are already seeing it today?
4. Is there a log line, Sidekiq job, or site setting that indicates the activation
status, so admins can confirm it rather than guessing?
## Context:
I checked with the Discourse Helper bot before posting, but it initially
interpreted my question as being about the _Yearly Review_ plugin (which is documented
to run Jan 1–31), then over-asserted that Rewind must already be live for my members
because “enabled = active.” That’s not true (or I’d see it myself), and there’s no
setting or doc that tells me one way or the other. This is what I’m trying
to find out.
Thanks!
