When we rebuild, we get the following error. can someone help me?
cd /var/discourse
./launcher rebuild app
FAILED
Pups::ExecError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' failed with return #<Process::Status: pid 1660 exit 2>
exec failed with the params "su postgres -c 'psql $db_name -c \"alter schema public owner to $db_user;\"'"
run the follow cmds for me and see if it helps
apt-get update
apt-get upgrade
after that, then run
cd /var/discourse
i run :
apt-get update
apt-get upgrade
but not found
[root@45 ~]# apt-get update
-bash: apt-get: command not found
[root@45 ~]# apt-get upgrade
what os are you running ?
maybe try sudo apt-get update & sudo apt-get upgrade
Thank you very much, we have successfully updated.
However, we use Centos, so we have:
yum update
Can you rebuild now?
yes, rebuild successful,
if you have the same error as me, you can follow this solution,
yum update
