Where can I create tags?
tagging
(Tenzan) #1
I have installed tagging plugin but can’t figure out where in discourse I can create tags.
(Stephanie) #2
I don’t think there’s a specific place to make a bunch of tags. (I could be wrong, I haven’t played with tags much yet.) As far as I can tell, you just create the tags on the topics.
(Stephanie) #3
(Tenzan) #4
I thought, the tags are created by admin, not users…
(Kane York) #5
By default, TL3+ can create tags. A tag that is already present on at least one visible topic is selectable by someone not permitted to create new ones.
(Tenzan) #6
Can you please point me where that place to create tags?
I couldn’t find it in admin panel.
(Kane York) #7
Because it’s not in the admin panel - it’s in the composer and the topic title edit UI.
A tag is “created” if it’s used at least once.
(Tenzan) #9
I think, this should be mentioned here The Official Discourse Tags Plugin: discourse-tagging in the Features.
(Sam Saffron) #10
it is now wiki, feel free to improve the copy, add screenshots and what not.
(Pad Pors) #11
I still can’t find it on a localhost machine. Is there any clue for tagging for the local host?
btw, can i add tag to topics in meta-discourse? since I even don’t find any options here or any tags attached to a topic.
(cpradio) #12
Did you installing the discourse-tagging plugin?
(Pad Pors) #13
yes, i’ve.
some information:
just installed the discourse on my ubuntu localhost.
installed tagging plugin & solved plugin.
I can see both in the setting of admin panel, but I can neither use tagging plugin nor see the solved plugin option in a category.
any problem with the installation? since other things goes quite well and i don’t know where to check?
(cpradio) #14
Provide a screenshot of your Admin > Plugins > Settings page, so I can see it.
(Pad Pors) #15
Thanks @cpradio.
it got solved by deleting stuff in ~/discourse/tmp/cache/ .
no idea what was the problem!
