Where can I fix my category ordering?
(Kevin Balla) #1
Hi all - wondering where I can fix my category ordering. I can’t find it under admin settings
(John Arce) #2
yourdomain.com/categories
then click
Then you will see this move/drag icon
Other option is just edit category > settings > position
(Jeff Atwood) #3
Not exactly. You need to set the admin setting fixed category positions first for this to work.
(@neil, should we be automagically setting this to true when someone attempts to set a category order in the UI?)
Bulk Select button and column disappears on /categories page when logged in
(Kane York) #4
How about this - show the position box in the edit menu, with a fa fa-lock and text saying this?
Manual category ordering is disabled. Click to enable.
Clear what’s actually happening, a clear action to take as opposed to magic, and certainly less clicks than going and setting the setting.
(Jeff Atwood) #5
That would be a good PR for you to work on, if you want to.
(Versus, say, lots of experimental UI that wasn’t quite what I had in mind ;))
(Jeff Atwood) #6
Ah, I just noticed we have this copy on the Settings page for category edit:
Categories will be displayed in order of activity. To control the order of categories in lists, enable the “fixed category positions” setting.
So really all we need is a link there that enables it.
(Kevin Balla) #7
Thanks guys! Just what I was looking for …
(Kkzhang) #8
I adjust the order of categories, but it works only in /categories page, but has not effect on here(as image)
I consider it may be a missing requirement or bug.
@sam @codinghorror
(cpradio) #9
See the following:
https://meta.discourse.org/t/category-ordering-broken-in-places/17025?source_topic_id=16074
#10
I checked fixed category positions
But I have no control of category ordering.
I have no visual of the wrench in my /cateigories
My Discourse is up to date! What am I missing? :disappointed_relieved:
(cpradio) #11
Wrench icon was removed. Click on each category, then the Edit Category button
#12
Yup… I found out the ‘position’ field. Thank you :+1:
(John Kowtko) #13
cpradioSenior Tester said –
" Wrench icon was removed. Click on each category, then the Edit Category button"
sorry, this is pretty poor usability …
(I geuss there is no quoting capability either?)
(cpradio) #14
Works fine… ? What are you struggling with in quoting?
(John Kowtko) #15
Here’s my screenshot …
… well, I have a screenshot, but the forum won’t let me upload it. So let me try to describe to you what I’m seeing …
Under your post I have the following options:
  • “heart”
  • link (chain)
  • bookmark (pennant)
  • Reply <- button
I see no quote control.
Since I am not allowed to upload files as a newbie, should I assume I’m not allowed to quote others either? Or is there a less discoverable quoting widget something that I haven’t found?
Thanks. John
(cpradio) #16
No, you can. Just either use the mouse to select the text you want to quote, or click reply and click the button in the editor.
Or use j or k to use keyboard navigation and when you are on the post you want to quote press q
(Jeff Atwood) #17
The first toolbar button in the editor. Try it out! In addition to what @cpradio said, select what you want to quote with your finger or mouse.
(Jeff Atwood) #21
