Where can I modify postgresql files?
(Chagara) #1
are they located in /var/discourse/shared/standalone ? are those the files I can change or do I have to go inside the container?
(Robby O'Connor) #2
@chagara, They are location in /var/discourse/shared/standalone/ – That is where all data volumes reside. The directory name hanging off of /var/discourse/shared/ will depend on how you are running your app – whether or not you are using a separate database and web container.
However, there is little to no reason to touch those.
