Where is my discourse in FTP filezilla?
(flexihack) #1
I used the Filezilla software on my computer to have access to folders and files. I have a Discourse installed on Digitalocean. Not sure where my discourse are located.
(flexihack) #2
No one? @codinghorror can you help me?
(Kane York) #3
The data files should be in the /var/discourse/shared/standalone/ folder.
But are you looking to modify the HTML Handlebars templates? You’ll need to write a plugin to do that.
(Mittineague) #4
Yes, replacing modified files via FTP is possible.
But doing so this way is a maintenance nightmare, you’ll need to do so every upgrade.
Not impossibble, but a real PITA
Much better to invest the time and effort into putting together a plugin that will deal with your modifications
(Kane York) #5
But you’ll also need to recompile assets if you change any JS files, in order for the changes to be, you know, actually picked up…
