Where is the source code in docker?
(Nagaraj P G) #1
Hi all,
I have installed discourse in docker on ubuntu 12.04 ( 3.8 Kernel ). I am not able to find the source code in the docker. The application is working fine, but where is the source code? so I can modify and see the changes.
Thank you
Nagaraj
(Arpit Jalan) #2
Hi, It’s not recommended to modify source code files directly, see this post for more info:
https://meta.discourse.org/t/how-do-you-setup-discourse-on-a-vps/14662/4?source_topic_id=14676
(Nagaraj P G) #3
Thank for the reply.
(Steve Diện) #4
You only can edit Discource source code in docker in terminal
cd /var/discourse
./launcher enter app
cd /var/www/discourse
You will see source of Discourse here
