Where to edit the 'Background color fade' on Forum List Items
(Michael) #1
Where can I edit the colour of the forum list background fade, for when you load the page.
Can’t seem to find it.
Thanks!
(Pad Pors) #2
you can either use a line of css code and put it in the /admin/customize/css_html panel or use the /admin/customize/colors panel and add new color theme.
or you may want to read more in some meta posts:
you’ll find more if you search more.
(Michael Wong) #3
THe thing is I have already customised all my colours - but the highlight is the default Discourse blue. Doesn’t seem to have a value for that?
(Pad Pors) #4
what do you mean bby highlight? may you show an image?
perhaps you can find out the corresponding css-id using inspect element.
(Michael Wong) #5
This highlight. It’s generated via Javascript on .topic-body
(Pad Pors) #6
i couldn’t find out the css class in the inspect-element as it’s a one moment color!
a simple guess is .alert div, which is light blue. you may like trying .alert{background-color: whatever} to see if it make any change, and then if it does, you need to find another class which is appropriate for topic-body (perhaps .topic-body .alert{}).
(cpradio) #7
Actually you want to override
.highlighted { background-color: ... }
(Joe Fedric) #8
This is no longer working. I looked for a newer topic, but didn’t find it. I’ve done extensive CSS modification to my install - this shouldn’t be failing.
Can someone take a look to see if this behavior has been modified in the js somewhere? It doesn’t seem to care what color I tell the class to be - defaults to discourse blue. I’m also working on a dark theme, and it’s pretty jarring.
(Rafael dos Santos Silva) #9
You can use this CSS to override the colors:
@keyframes background-fade-highlight {
    0% {
        background-color: #ffaa00 /* Pick a strong color, animation starts here */
    100% {
        background-color: #ffffff /* The default post background color*/
(Joe Fedric) #10
ARGH
… this is what I suspected, but I wasn’t able to locate the CSS class I needed. I made my own @keyframes animations for the spinner and a few other elements on the install, so when the normal CSS wasn’t working, I figured it was an animation, or a JS thing. Thank you for confirming this for me, I was going a bit crazy looking for it.
(Rafael dos Santos Silva) #11
This was a JS animation that changed to pure CSS recently, so I believe that’s why you couldn’t find it.
(Joe Fedric) #12
As long as it works, idgaf!
Also, hopefully this helps anyone else that runs into this in the future :slight_smile:
