White page after upgrade
Hello,
I am having White page issue after upgrade. I have also getting White page on admin pages too so i can’t reach dashboard.
I have done rebuild but all same.
web site : www.finliz.com
Try removing all plugins and rebuilding.
Hello Sam Saffron,
Thank you for your quick reply. I am not installed any plugin. Just core discourse installation.
This is a custom port, we only support discourse on port 443 or in some exceptional cases port 80
Discourse was running fine until i update :frowning:
It appears that you have some problems according to MX-Toolbox.
10 Problems
Category Host Result
dmarc finliz.com DNS Record not found More Info
https finliz.com The Certificate has a name mismatch More Info
dns finliz.com Primary Name Server Not Listed At Parent More Info
mx finliz.com No DMARC Record found More Info
dns finliz.com Local NS list does not match Parent NS list More Info
dns finliz.com Name Servers are on the Same Subnet More Info
dns finliz.com SOA Serial Number Format is Invalid More Info
dns finliz.com SOA Expire Value out of recommended range More Info
mx finliz.com DMARC Quarantine/Reject policy not enabled More Info
smtp mx.yandex.net Reverse DNS does not match SMTP Banner More Info
You may also want to check out the following link. Your connection is not secure and you have a loop - http redirecting to http. Although the report is lengthy, scroll down through it. It reports many errors.
https://check-your-website.server-daten.de/?q=finliz.com
