Why are there hashes in the DB for users generated via OAuth?
(Norandom) #1
Hey,
I took a look at the discourse-oauth2-basic plugin because we want to use it with Single Sign On.
I generated a couple of accounts via the oauth workflow / login method.
discourse=# select username_lower, auth_token from users;
username_lower  |            auth_token
 username       | cblalblalala
I took a look at the plugin code Add option for setting Authorization header · discourse/discourse-oauth2-basic@7584d84 · GitHub but it does not seem to store the bearer tokens.
What are these auth_tokens?
Best,
Marius
