Why email error sending? Discourse does not connect to SMTP
(Edison) #1
Why email error sending? Discourse does not connect to SMTP.
(Joshua Rosenfeld) #2
@kudouyuzi, I don’t mean to be rude - but just like your previous support topic, we need far more details if we’re going to help you.
At what point in the install process does email error, or did you site previously work and it has now stopped working?
Have you attempted everything in the email troubleshooting #howto?
(Edison) #3
DISCOURSE_SMTP_ADDRESS: 'smtp.mydomain.xyz’
DISCOURSE_SMTP_PORT: 587
DISCOURSE_SMTP_USER_NAME: 'sender@mydomain.xyz’
DISCOURSE_SMTP_PASSWORD: "passwd98787"
DISCOURSE_SMTP_ENABLE_START_TLS: true
This is my smtp info
(Edison) #4
Sent mail to xxxxxx@gmail.com (10364.6ms)
Job exception: hostname “smtp.mydomain.xyz” does not match the server certificate
(Joshua Rosenfeld) #5
@kudouyuzi, are you running your own email server, or using one of the suggested providers? If custom, I’m not going to be of any help.
(Edison) #6
have tried those providers that you have said, but got same problem
(Joshua Rosenfeld) #7
The recommended providers are used every week by numerous people (like @pfaffman) to set up new Discourse sites. If you pick a single recommended provider and let us know the exact error you receive - then we can help. Email is far too complicated to assist in troubleshooting a personal mail server.
(Jay Pfaffman) #8
This implies that your SMTP’s TLS certificate is wrong or bogus.
If you, in fact, got this very same error with Mailgun or Sparkpost, then there is something wrong with your internet connection (like someone between you and the SMTP provider is doing something they shouldn’t).
(Edison) #9
Email working well.
and got these 2 errors
Error connecting to Redis on localhost:6379 (Errno::ECONNREFUSED) subscribe failed, reconnecting in 1 second. Call stack ["/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:345:in rescue in establish_connection'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:331:inestablish_connection’", “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:101:in block in connect'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:293:inwith_reconnect’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:100:in connect'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:364:inensure_connected’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:221:in block in process'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:306:inlogging’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:220:in process'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:134:inblock in call_loop’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:280:in with_socket_timeout'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:133:incall_loop’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/subscribe.rb:43:in subscription'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/subscribe.rb:12:insubscribe’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:2760:in _subscription'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:2138:inblock in subscribe’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:58:in block in synchronize'", "/usr/local/lib/ruby/2.3.0/monitor.rb:214:inmon_synchronize’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:58:in synchronize'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:2137:insubscribe’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus/backends/redis.rb:304:in global_subscribe'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus.rb:513:inglobal_subscribe_thread’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus.rb:461:in `block in new_subscriber_thread’”]
Job exception: Error connecting to Redis on localhost:6379 (Errno::ECONNREFUSED)
Error connecting to Redis on localhost:6379 (Errno::ECONNREFUSED) subscribe failed, reconnecting in 1 second. Call stack ["/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:345:in `rescue in establish_connection'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:331:in `establish_connection'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:101:in `block in connect'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:293:in `with_reconnect'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:100:in `connect'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:364:in `ensure_connected'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:221:in `block in process'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:306:in `logging'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:220:in `process'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:120:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:862:in `block in get'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:58:in `block in synchronize'", "/usr/local/lib/ruby/2.3.0/monitor.rb:214:in `mon_synchronize'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:58:in `synchronize'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:861:in `get'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus/backends/redis.rb:252:in `process_global_backlog'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus/backends/redis.rb:287:in `block in global_subscribe'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus/backends/redis.rb:301:in `global_subscribe'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus.rb:513:in `global_subscribe_thread'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus.rb:461:in `block in new_subscriber_thread'"]
(Jay Pfaffman) #10
Did you follow the install cloud instructions?
(Edison) #11
Yes, followed the install cloud instructions
