Why I cant have more than 20000 API calls?
(Hosein Naseri) #1
My needs are something like 100000 api calls per day. But in admin panel I can only increase it up to 20000 api calls. What can I do?
(Sam Saffron) #2
The text says “max user api reqs per day” this is for the user API not admin API which is very likely what you are using.
(Matt Palmer) #3
Reconsider your approach. Servicing 100,000 API calls per user per day is going to get very, very expensive very quickly.
