Why the composer window is making a single word bold without reason?
See the last word #praise which is being bold even I don’t want it to be.
I’ve tried enclosing the same with two asterisks (**) . But the same still remains bold.
If I remove hash, then its unbold. If I give one space after #, then it becomes heading1.
If I cut paste it elsewhere in the same window, it still remains bold.
Any idea?
Is it the name of one of your categories/tags? It seems to be turning into a category/tag link.
This seems to work as a workaround:
#<hairsp>praise
#praise
(Edited to include ‘tags’, for future reference)
good catch @JammyDodger
No, there is no category named ‘Praise’. But there IS a tag named ‘praise’.
Very sorry for late reply.
Maybe an auto-replace in your Watched Words?
I’m not sure what else would apply auto-formatting? :thinking: Does it do it in safe-mode?
No I didn’t set any auto-replace, or set anything about ‘watched words’.
I checked and found that the same shows as it is in ‘safe-mode’ also.
(btw, when I enter in complete safe mode, disabling all 3 things, then when I navigate to that offending topic by search box, not thru the url bar directly, the word ‘safe-mode’ disappears from url bar.)
But from your reply, one thing I got in good direction is that it has some problem with the exact word/spelling ‘praise’ only. So, there must be something along the lines you said.
maybe on of your categories has a Category Slug called praise ?
Not possible. Because I never renamed any category manually (and there’s no category named ‘praise’).
But, as said in my edited answer above, I do have a tag named ‘praise’.
That’ll be it then :slightly_smiling_face:
then that is it. if you click on it, it should show all the topics with the tag then :slight_smile:
So, I accept this as a solution.
Thanks ji.
