Wierd problem with uploading avatar via api
(Hosein Naseri) #1
When I use
curl -X POST --data "user_id=103&type=avatar&file=@/home/mypicture.png&api_key=myapikey&api_username=myuser" https://talk.zabanshenas.com/uploads.json
I get success:OK.
but i want to get the image id so according to api doc I add “synchronous”: true. However this time the response is nothing. why?
curl -X POST --data "user_id=103&type=avatar&synchronous=true&file=@/home/mypicture.png&api_key=myapikey&api_username=myuser" https://talk.zabanshenas.com/uploads.json
Is there something I should do to get this working?
(Blake Erickson) #2
maybe try files[] instead of file?
Here is a working example with a response:
(Hosein Naseri) #3
I have also tried it with files but i get nothing in response. Any idea?
btw what is the software behind that picture you send?
(Hosein Naseri) #4
this is also the php code I’m trying to upload avatars with:
public static function UploadAvatar($user_id, $file, $fileName){
        $data = array(  'api_key'=>self::$api_key,
                        'api_username'=>self::$api_user,
                        'type'=>'avatar',
                        'files[]'=>'@'.$file . ';filename='.$fileName,
                        'user_id'=>$user_id, );
                        print_r($data);
        $ch = curl_init();
        curl_setopt($ch, CURLOPT_URL, self::$discourse_url."uploads.json?");
        curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
        curl_setopt($ch, CURLOPT_POST, 1);
        curl_setopt($ch, CURLOPT_POSTFIELDS, $data);
        $response = curl_exec($ch);
        curl_close($ch);
        return $response;
this will response in success:OK
however if i add synchronous= true, again I get no response.
(Hosein Naseri) #5
There is a similar issue here but i don’t understand how @sleep solved their problem.
(Blake Erickson) #6
It’s postman. Please try using it. It might be able to export to curl. I’m not sure though.
(Blake Erickson) #7
What is the ‘@’ for?
(Hosein Naseri) #8
I don’t know. I just copied it from other examples. however I tried it without @ and I get the same thing as I described.
I tried postman and I get the correct response when I add synchronous. However when I export postman as curl and I use it, I will get no response. It’s really weird to me.
(Hosein Naseri) #9
I have noticed that there are some errors in discourse log when Im trying to upload image using curl command with shell or php. for example:
NoMethodError (undefined method `tempfile' for "/home/hnaseri/Pictures/hosein.png":String)
/var/www/discourse/app/controllers/uploads_controller.rb:73:in `create_upload'
/var/www/discourse/app/controllers/uploads_controller.rb:22:in `create'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal/implicit_render.rb:4:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/abstract_controller/base.rb:198:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal/rendering.rb:10:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/callbacks.rb:117:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/callbacks.rb:555:in `block (2 levels) in compile'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/callbacks.rb:505:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/callbacks.rb:92:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/callbacks.rb:778:in `_run_process_action_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/callbacks.rb:81:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal/rescue.rb:29:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/notifications.rb:164:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/notifications.rb:164:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.7.1/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/abstract_controller/base.rb:137:in `process'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionview-4.2.7.1/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-mini-profiler-0.10.1/lib/mini_profiler/profiling_methods.rb:76:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal.rb:196:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_controller/metal.rb:237:in `block in action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/routing/route_set.rb:74:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/routing/route_set.rb:43:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/journey/router.rb:43:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/journey/router.rb:30:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/journey/router.rb:30:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/routing/route_set.rb:817:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.3.1/lib/omniauth/strategy.rb:186:in `call!'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.3.1/lib/omniauth/strategy.rb:164:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.3.1/lib/omniauth/builder.rb:63:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/conditionalget.rb:38:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/head.rb:13:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:138:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/params_parser.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/flash.rb:260:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/session/abstract/id.rb:225:in `context'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/session/abstract/id.rb:220:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/cookies.rb:560:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.7.1/lib/active_record/query_cache.rb:36:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.7.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/callbacks.rb:88:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/callbacks.rb:778:in `_run_call_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/remote_ip.rb:78:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/logster-1.2.7/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7.1/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7.1/lib/rails/rack/logger.rb:22:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:17:in `call_with_quiet_assets'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7.1/lib/action_dispatch/middleware/request_id.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/methodoverride.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/runtime.rb:18:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/sendfile.rb:113:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-mini-profiler-0.10.1/lib/mini_profiler/profiler.rb:171:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus/rack/middleware.rb:62:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:73:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7.1/lib/rails/engine.rb:518:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7.1/lib/rails/application.rb:165:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7.1/lib/rails/railtie.rb:194:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7.1/lib/rails/railtie.rb:194:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/urlmap.rb:66:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/urlmap.rb:50:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.5/lib/rack/urlmap.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.2.0/lib/unicorn/http_server.rb:562:in `process_client'
/var/www/discourse/lib/scheduler/defer.rb:85:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.2.0/lib/unicorn/http_server.rb:658:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.2.0/lib/unicorn/http_server.rb:508:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.2.0/lib/unicorn/http_server.rb:132:in `start'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.2.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/bin/unicorn:22:in `load'
/var/www/discourse/vendor/bundle/ruby/2.3.0/bin/unicorn:22:in `<main>'
Any Idea?
(Hosein Naseri) #10
when Im using curl but without synchronous=true, I get success:OK However there is also an error log for this in logs too:
Job exception: undefined method `tempfile' for "/home/hnaseri/Pictures/hosein.png":String
/var/www/discourse/app/controllers/uploads_controller.rb:26:in `block in create'
/var/www/discourse/lib/scheduler/defer.rb:68:in `do_work'
/var/www/discourse/lib/scheduler/defer.rb:46:in `do_all_work'
/var/www/discourse/lib/scheduler/defer.rb:86:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.2.0/lib/unicorn/http_server.rb:519:in `maintain_worker_count'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.2.0/lib/unicorn/http_server.rb:283:in `join'
which is a little different than when synchronous=true is in the curl.
On the other hand, uploading with postman doesn’t produce any error. So at this point I really have no idea whats the problem. Am I doing something wrong?
(Hosein Naseri) #11
Finally we found the problem. as of newer version of php, it seems $args['file'] = '@/path/to/file'; is depreciated and we need to use:
new CurlFile('filename.png', 'image/png');
more information could be found here:
https://wiki.php.net/rfc/curl-file-upload
#12
Hey there, when uploading an avatar via theDiscourse API (hosted myself)I am having problems with:
failed with status 422, response {“failed”:“FAILED”,“message”:"undefined method `tempfile’
it works fine with Postman using main API key and an admin account username:
when i use the following code in PHP using Curl:
$url = 'http://forum-domain.xyz/uploads.json?api_key=b0c1561e9e32ad5d3121234d361b1ea490f1b035ed45433743ed53bd92cc8461&api_username=ashadmin';
$avFile = new CurlFile('stevemc.jpg', 'image/jpg');
$data = [
    "files" => [$avFile],
    "type" => "avatar",
    "user_id" => $uid,
    "synchronous" => true,
$response = discourseApi($url,$data);
echo '<pre>';
print_r($response );
echo '</pre>';
function discourseApi($url,$data=[], $mode='post'){
    $content = json_encode($data);
    $curl = curl_init($url);
    curl_setopt($curl, CURLOPT_HEADER, false);
    curl_setopt($curl, CURLOPT_RETURNTRANSFER, true);
    curl_setopt($curl, CURLOPT_HTTPHEADER, array("Content-type: application/json"));
    if($mode=='post'){
        curl_setopt($curl, CURLOPT_POST, true);
        curl_setopt($curl, CURLOPT_POSTFIELDS, $content);
    if($mode=='put'){
        curl_setopt($curl, CURLOPT_CUSTOMREQUEST, "PUT");
    $json_response = curl_exec($curl);
    $status = curl_getinfo($curl, CURLINFO_HTTP_CODE);
    if ( $status != 200 ) {
        die("Error: call to URL $url failed with status $status, response $json_response, curl_error " . curl_error($curl) . ", curl_errno " . curl_errno($curl));
    curl_close($curl);
    $response = json_decode($json_response, true);
    return $response;
It just breaks horribly. The image is in the root of the site as is the php script so figured “stevemc.jpg” would be fine, though I have also tried @/home/forum-folder/public_html/stevemc.jpg with and without @. I have also tried changing the format of the data array several ways:
$data = [
    "files" => [$avFile],               // this line
    "type" => "avatar",
    "user_id" => $uid,
to be the following:
"file" => $avFile,
"files" => $avFile,
"file" => [$avFile],
"files[]" => $avFile,
"files[]" => [$avFile],
Basically none of these variations with anything seems to work, including the
new CurlFile(‘stevemc.jpg’, ‘image/jpg’);
stuff which is really annoying as I would like to try and pull all avatars from old forum software and apply them to new users created through the API, the rest of which is working great so far!
(Blake Erickson) #13
I’m not sure about the PHP syntax, but this is the curl syntax that worked for me:
curl -i -sS -X POST "http://localhost:3000/uploads.json" \
-H "Api-Key: 3f1eea80af3f6285313d676a37ca24481737bc83dc05cb05baa439d660f01727" \
-H "Api-Username: system" \
-F "files[]=@/home/blake/Downloads/codinghorror.png" \
-F "type=avatar"
-F "user_id=1"
-F "synchronous=true"
HTTP/1.1 200 OK
{"id":5,"url":"/uploads/default/original/1X/79b7c683e4e526242c4427eb2a44ddc9d82c3f2d.png","original_filename":"codinghorror.png","filesize":30866,"width":360,"height":360,"thumbnail_width":360,"thumbnail_height":360,"extension":"png","short_url":"upload://hmLvGk1P1fmXHe1kSiUMKwmUiUR.png","retain_hours":null,"human_filesize":"30.1 KB"}
Looking at your code above, make sure that you are using application/form-data like you are in postman instead of application/json which it appears you are using in your php code (the -F option in curl will use form-data).
Also, once the avatar is uploaded be sure to make another api request to assign it.
#14
Thank you very much Blake, I will try this again a bit later today/tomorrow. Hopefully if it works I can get back to having fun with the discord bot I’m making to pass data to/from discourse :grin:
