Wierd thing happened while rebuild
Hello,
Now i have no any errors but my forum is slower then before. Today i run a rebuild and it runs slower also then before but no errors. But when it start compiling css it generate a huge i think uncompressed thing which is maybe the theme components or something like that.
I paste it some but not the all because it huuuuge. :slight_smile:
Is that anybody have idea what is happening? Thank you! :slight_smile:
The thing when start
2020-09-02 08:41:50.909 UTC [3984] discourse@discourse LOG: duration: 145.625 ms execute <unnamed>: INSERT INTO "stylesheet_cache" ("target", "digest", "content", "created_at", "updated_at", "source_map") VALUES ('desktop_69', 'e3003e16126ac030090a30caa103ff3803a4b4fa', '/*! normalize.css v8.0.1 | MIT License | github.com/necolas/normalize.css */html{line-height:1.15;-webkit-text-size-adjust:100%}body{margin:0}main{display:block}h1{font-size:2em;margin:0.67em 0}hr{box-sizing:content-box;height:0;overflow:visible}pre{font-family:monospace, monospace;font-size:1em}a{background-color:transparent}abbr[title]{border-bottom:none;text-decoration:underline;text-decoration:underline dotted}b,strong{font-weight:bolder}code,kbd,samp{font-family:monospace, monospace;font-size:1em}small{font-size:80%}sub,sup{font-size:75%;line-height:0;position:relative;vertical-align:baseline}sub{bottom:-0.25em}sup{top:-0.5em}img{border-style:none}button,input,optgroup,select,textarea{font-family:inherit;font-size:100%;line-height:1.15;margin:0}button,input{overflow:visible}button,select{text-transform:none}button,[type="button"],[type="reset"],[type="submit"]{-webkit-appearance:button}button::-moz-focus-inner,[type="button"]::-moz-focus-inner,[type="reset"]::-moz-focus-inner,[type="submit"]::-moz-focus-inner{border-style:none;padding:0}button:-moz-focusring,[type="button"]:-moz-focusring,[type="reset"]:-moz-focusring,[type="submit"]:-moz-focusring{outline:1px dotted ButtonText}fieldset{padding:0.35em 0.75em 0.625em}legend{box-sizing:border-box;color:inherit;display:table;max-width:100%;padding:0;white-space:normal}progress{vertical-align:baseline}textarea{overflow:auto}[type="checkbox"],[type="radio"]{box-sizing:border-box;padding:0}[type="number"]::-webkit-inner-spin-button,[type="number"]::-webkit-outer-spin-button{height:auto}[type="search"]{-webkit-appearance:textfield;outline-offset:-2px}[type="search"]::-webkit-search-decoration{-webkit-appearance:none}::-webkit-file-upload-button{-webkit-appearance:button;font:inherit}details{display:block}summary{display:list-item}template{display:none}[hidden]{display:none}button,input,optgroup,select,textarea{color:inherit}table{border-collapse:collapse;border-spacing:0}td,th{padding:0}/*!
After this Pikaday huge css
than
	/*# sourceMappingURL=desktop_69_e3003e16126ac030090a30caa103ff3803a4b4fa.css.map */', '2020-09-02 08:41:50.680147', '2020-09-02 08:41:50.680147', '{
		"version": 3,
		"file": "desktop.css",
		"sources": [
			"desktop.scss",
			"app/assets/stylesheets/common.scss",
			"app/assets/stylesheets/vendor/normalize.scss",
			"app/assets/stylesheets/vendor/normalize-ext.scss",
			"app/assets/stylesheets/vendor/pikaday.scss",
			"app/assets/stylesheets/common/foundation/variables.scss",
			"theme_colors.scss",
			"app/assets/stylesheets/common/foundation/math.scss",
			"app/assets/stylesheets/common/foundation/color_transformations.scss",
			"app/assets/stylesheets/common/foundation/mixins.scss",
			"app/assets/stylesheets/common/foundation/helpers.scss",
			"app/assets/stylesheets/common/foundation/base.scss",
			"app/assets/stylesheets/common/select-kit/notifications-filter.scss",
			"app/assets/stylesheets/common/select-kit/single-select.scss",
			"app/assets/stylesheets/common/select-kit/mini-tag-chooser.scss",
			"app/assets/stylesheets/common/select-kit/tag-drop.scss",
			"app/assets/stylesheets/common/select-kit/combo-box.scss",
			"app/assets/stylesheets/common/select-kit/future-date-input-selector.scss",
			"app/assets/stylesheets/common/select-kit/category-row.scss",
			"app/assets/stylesheets/common/select-kit/list-setting.scss",
			"app/assets/stylesheets/common/select-kit/notifications-button.scss",
			"app/assets/stylesheets/common/select-kit/pinned-button.scss",
			"app/assets/stylesheets/common/select-kit/category-drop.scss",
			"app/assets/stylesheets/common/select-kit/icon-picker.scss",
			"app/assets/stylesheets/common/select-kit/user-notifications-dropdown.scss",
			"app/assets/stylesheets/common/select-kit/dropdown-select-box.scss",
			"app/assets/stylesheets/common/select-kit/composer-actions.scss",
			"app/assets/stylesheets/common/select-kit/categories-admin-dropdown.scss",
			"app/assets/stylesheets/common/select-kit/category-chooser.scss",
			"app/assets/stylesheets/common/select-kit/category-selector.scss",
			"app/assets/stylesheets/common/select-kit/select-kit.scss",
			"app/assets/stylesheets/common/select-kit/period-chooser.scss",
			"app/assets/stylesheets/common/select-kit/multi-select.scss",
			"app/assets/stylesheets/common/select-kit/toolbar-popup-menu-options.scss",
			"app/assets/stylesheets/common/select-kit/color-palettes.scss",
			"app/assets/stylesheets/common/select-kit/topic-notifications-button.scss",
			"app/assets/stylesheets/common/select-kit/tag-chooser.scss",
			"app/assets/stylesheets/common/select-kit/user-row.scss",
			"app/assets/stylesheets/common/components/groups-form-membership-fields.scss",
			"app/assets/stylesheets/common/components/conditional-loading-section.scss",
			"app/assets/stylesheets/common/components/navs.scss",
			"app/assets/stylesheets/common/components/svg.scss",
			"app/assets/stylesheets/common/components/badges.scss",
			"app/assets/stylesheets/common/components/date-time-input-range.scss",
			"app/assets/stylesheets/common/components/date-picker.scss",
			"app/assets/stylesheets/common/components/bookmark-modal.scss",
			"app/assets/stylesheets/common/components/buttons.scss",
			"app/assets/stylesheets/common/components/hashtag.scss",
			"app/assets/stylesheets/common/components/time-input.scss",
			"app/assets/stylesheets/common/components/convert-to-public-topic-modal.scss",
			"app/assets/stylesheets/common/components/widget-dropdown.scss",
			"app/assets/stylesheets/common/components/tap-tile.scss",
			"app/assets/stylesheets/common/components/iframed-html.scss",
			"app/assets/stylesheets/common/components/user-stream-item.scss",
			"app/assets/stylesheets/common/components/user-info.scss",
			"app/assets/stylesheets/common/components/share-and-invite-modal.scss",
			"app/assets/stylesheets/common/components/user-card.scss",
			"app/assets/stylesheets/common/components/date-time-input.scss",
			"app/assets/stylesheets/common/components/banner.scss",
			"app/assets/stylesheets/common/components/user-stream.scss",
			"app/assets/stylesheets/common/components/footer-nav.scss",
			"app/assets/stylesheets/common/components/bookmark-list.scss",
			"app/assets/stylesheets/common/components/keyboard_shortcuts.scss",
			"app/assets/stylesheets/common/components/group-member-dropdown.scss",
			"app/assets/stylesheets/common/components/ignored-user-list.scss",
			"app/assets/stylesheets/common/components/date-input.scss",
			"app/assets/stylesheets/common/input_tip.scss",
			"app/assets/stylesheets/common/topic-entrance.scss",
			"app/assets/stylesheets/common/printer-friendly.scss",
			"app/assets/stylesheets/common/base/request-group-membership-form.scss",
			"app/assets/stylesheets/common/base/tooltip.scss",
			"app/assets/stylesheets/common/base/not-found.scss",
			"app/assets/stylesheets/common/base/onebox.scss",
			"app/assets/stylesheets/common/base/lightbox.scss",
			"app/assets/stylesheets/common/base/group.scss",
			"app/assets/stylesheets/common/base/history.scss",
			"app/assets/stylesheets/common/base/magnific-popup.scss",
			"app/assets/stylesheets/common/base/cat_reorder.scss",
			"app/assets/stylesheets/common/base/user.scss",
			"app/assets/stylesheets/common/base/upload.scss",
			"app/assets/stylesheets/common/base/rtl.scss",
			"app/assets/stylesheets/common/base/about.scss",
			"app/assets/stylesheets/common/base/colorpicker.scss",
			"app/assets/stylesheets/common/base/directory.scss",
			"app/assets/stylesheets/common/base/crawler_layout.scss",
			"app/assets/stylesheets/common/base/reviewables.scss",
			"app/assets/stylesheets/common/base/redirection.scss",
			"app/assets/stylesheets/common/base/popup-menu.scss",
			"app/assets/stylesheets/common/base/_topic-list.scss",
			"app/assets/stylesheets/common/base/composer-user-selector.scss",
			"app/assets/stylesheets/common/base/request_access.scss",
			"app/assets/stylesheets/common/base/edit-topic-status-update-modal.scss",
			"app/assets/stylesheets/common/base/d-popover.scss",
			"app/assets/stylesheets/common/base/header.scss",
			"app/assets/stylesheets/common/base/code_highlighting.scss",
			"app/assets/stylesheets/common/base/groups.scss",
			"app/assets/stylesheets/common/base/category-list.scss",
			"app/assets/stylesheets/common/base/compose.scss",
			"app/assets/stylesheets/common/base/topic-post.scss",
			"app/assets/stylesheets/common/base/emoji.scss",
			"app/assets/stylesheets/common/base/user-badges.scss",
			"app/assets/stylesheets/common/base/ember-select.scss",
			"app/assets/stylesheets/common/base/modal.scss",
			"app/assets/stylesheets/common/base/search.scss",
			"app/assets/stylesheets/common/base/alert.scss",
			"app/assets/stylesheets/common/base/menu-panel.scss",
			"app/assets/stylesheets/common/base/d-icon.scss",
			"app/assets/stylesheets/common/base/shared-drafts.scss",
			"app/assets/stylesheets/common/base/faqs.scss",
			"app/assets/stylesheets/common/base/topic.scss",
			"app/assets/stylesheets/common/base/explain-reviewable.scss",
			"app/assets/stylesheets/common/base/discourse.scss",
			"app/assets/stylesheets/common/base/search-menu.scss",
			"app/assets/stylesheets/common/base/activation.scss",
			"app/assets/stylesheets/common/base/exception.scss",
			"app/assets/stylesheets/common/base/share_link.scss",
			"app/assets/stylesheets/common/base/bbcode.scss",
			"app/assets/stylesheets/common/base/tagging.scss",
			"app/assets/stylesheets/common/base/login.scss",
			"app/assets/stylesheets/common/base/username_tagsinput.scss",
			"app/assets/stylesheets/common/base/topic-admin-menu.scss",
			"app/assets/stylesheets/common/d-editor.scss",
			"app/assets/stylesheets/common/topic-timeline.scss",
			"app/assets/stylesheets/common/fonts.scss",
			"app/assets/stylesheets/desktop/group.scss",
			"app/assets/stylesheets/desktop/history.scss",
			"app/assets/stylesheets/desktop/user.scss",
			"app/assets/stylesheets/desktop/upload.scss",
			"app/assets/stylesheets/desktop/latest-topic-list.scss",
			"app/assets/stylesheets/desktop/topic-list.scss",
			"app/assets/stylesheets/desktop/header.scss",
			"app/assets/stylesheets/desktop/category-list.scss",
			"app/assets/stylesheets/desktop/compose.scss",
			"app/assets/stylesheets/desktop/topic-post.scss",
			"app/assets/stylesheets/desktop/modal.scss",
			"app/assets/stylesheets/desktop/admin_customize.scss",
			"app/assets/stylesheets/desktop/banner.scss",
			"app/assets/stylesheets/desktop/menu-panel.scss",
			"app/assets/stylesheets/desktop/topic.scss",
			"app/assets/stylesheets/desktop/discourse.scss",
			"app/assets/stylesheets/desktop/login.scss",
			"app/assets/stylesheets/desktop/components/user-stream-item.scss",
			"app/assets/stylesheets/desktop/components/user-info.scss",
			"app/assets/stylesheets/desktop/components/user-card.scss",
			"category_background.scss"
Than huge source content
		"sourcesContent": [
			"@import \"common\";\n\n@import \"desktop/*\";\n\n// Import all component-specific files\n@import \"desktop/components/*\";\n\n/* These files doesn''t actually exist, they are injected by Stylesheet::Compiler. */\n\n@import \"category_backgrounds\";\n",
		"@import \"vendor/normalize\";\n@import \"vendor/normalize-ext\";\n@import \"vendor/pikaday\";\n@import \"common/foundation/helpers\";\n@import \"common/foundation/base\";\n@import \"common/foundation/mixins\";\n@import \"common/foundation/variables\";\n@import \"common/select-kit/*\";\n@import \"common/components/*\";\n@import \"common/input_tip\";\n@import \"common/topic-entrance\";\n@import \"common/printer-friendly\";\n@import \"common/base/*\";\n@import \"common/d-editor\";\n@import \"common/topic-timeline\";\n@import \"common/fonts\";\n",
