Wiki post blank OK box
(Filip) #1
Recently, all the wiki posts on a forum I use have bugged out and when you edit them and click “save edit” it just gives you a blank error box with “ok” on.
Why is this bug caused? How do we fix it?
(Jeff Atwood) #2
Update to latest. This was a bug introduced with tagging changes but has since been fixed.
(Filip) #3
Ok, I think the forums just updated a few mins ago. Let me check if it works.
(Filip) #4
It worked for about half an hour, and then the bug returned?
(Jeff Atwood) #5
See if you can repro on try.discourse.org – I will make a topic wiki there.
(Filip) #7
It’s still going on @codinghorror , could it have something to do with the fact it’s in a pm?
(Jeff Atwood) #8
Wow you guys made a private message a Wiki post???
(Filip) #9
Yeah, we’re writing a project all together, and it’s easier to edit our parts in than to post the source code and have 1 person fit them all together.
Will that be the problem then?
(Kane York) #10
Wait, you’re using a forum for source control???
https://bitbucket.org/ has free private repositories for up to 5 users.
(Jens Maier) #11
Speaking of which… feature idea:
Discourse has a full history of edits. It should be possible to merge conflicting changes by 3-way diffing the user’s new version, the version they started editing and the current top version. Might be useful for wiki posts in busy forums.
(Filip) #12
The thing is, Wiki posts used to work in PMs, now they’ve stopped.
@riking we’re formatting it with Markdown to be posted on Discourse later, so we like to instantly see results. The Wiki post also has edit history which comes in handy.
#13
Called it.
(Régis Hanol) #14
If they ever did, it was a side-effect. Was never intended nor tested for.
(Yamikuronue) #15
We’ve done that for other reasons pertaining to our Sekret PM Club on WTDWTF as well…
We’re running roleplay games, and we made the list of characters a wiki so we could add to it as we go.
(Filip) #16
@yamikuronue did it work for you?
(Yamikuronue) #17
Yes, but the posts in question were from December, so it may have been broken since.
ETA: I can definitely still edit them though, even the ones I didn’t post
Far as I can tell we’re on 1.2.0.beta9
(Filip) #18
I’ve just figured out that I can’t seem to edit any posts that begin pm’s. I’ll test now on some other forums to see if it’s just mine.
EDIT: everything seems fine on other forums. I’ll ask my forum’s Admins about it.
(Sam Saffron) #19
I don’t want to tell you “YOUR DOING IT WRONG” … but personally I think groups are a much better fit for that kind of collaboration.
(Yamikuronue) #20
:smiley: yeah, I just didn’t want to bug the forum admins for something this orthogonal to the forum’s purpose, so I invented the Sekret PM Club instead
(Sam Saffron) #21
We have a concept of “group manager” planned which would really help for this kind of stuff, so the forum admins could just create a group for you and make you manager of it so you can control membership.
