Will Discourse patch against POODLE SSLv3 vulnerability?
(Michael Downey) #1
Since Discourse ships with Nginx, and SSL is an officially-supported option, will there be any kind of update automatically pushed out to disable SSLv3 to protect against the newly-announced POODLE vulnerability?
A nice summary from Digital Ocean: How To Protect your Server Against the POODLE SSLv3 Vulnerability | DigitalOcean
If this isn’t something that can be pushed out automatically with an update, can someone either write up a fix document or maybe update the HOWTO for SSL?
(Dave Shaw) #2
Is SSL 3.0 enabled on your site?
It’s not on mine.
Try something like https://www.poodlescan.com/ to see if it is.
(Jeff Atwood) #3
Our base Docker image never supported ssl v3 in the first place, so this is a non issue for us.
(Jeff Atwood) #4
