Will this work for hosting Discourse myself?
(Alex) #1
This is what I’m going after, before I make and host my own Discourse website.
:black_small_square: DigitalOcean [4 GB RAM, 2 vCPUs, 80 GB SSD DISK] ($20/month plan)
:black_small_square: Elastic Email (150,000 emails/month is free)
:black_small_square: SSL certificate from my domain host (domain.com)
TOTAL: $30-35~
Am I missing anything required before starting my discourse website and hosting it myself?
I have not signed up for Discourse or DigitalOcean yet
(Bhanu Sharma) #2
Definitely would work.
Should work as long as you don’t have a plan to run your discourse in mailing list mode.
You probably won’t need this as discourse will install SSL on it’s own using letsencrypt.
#3
If you self host you don’t need to :slight_smile:
(Alex) #4
Excellent! :grin: What is mailing list mode?
(Bhanu Sharma) #5
Simply stated, mailing list mode allows your users to use forum only by interacting with emails. No need to visit a website.
(Alex) #6
Oh I see, how can I make that possible on a self-hosted Discourse website?
(Bhanu Sharma) #7
There is a setting in admin panel. It doesn’t makes a difference if your site is self hosted or discourse hosted. If you have configured inbound and outbound emailing properly then there shouldn’t be any issue.
(Jay Pfaffman) #8
Unless you know that you’re going to have lots of users, I would start with a $5 or $10/month droplet. It’s what I recommend for my standard installs. I generally recommend Mailgun because it’s easy to get configured, but Elastic Email should work too.
(Alex) #9
Mailgun is 10k free emails a month while ElasticEmail is 150k free…
(Jay Pfaffman) #10
I see a fair number of topics where people have had trouble with elastic email, but I’m going to give it another look soon
10,000 emails per month is quite enough for a small community.
(Christoph) #11
The problem is that EM is very rigid with adding an unsubscribe link and your address to the bottom of each and every outgoing email. Their logic is a mailinglist logic, not transactional emails. In my opinion, EM is simply not suitable for use with discourse:
Handling bouncing e-mails
(Jay Pfaffman) #12
Sounds like you just saved me some time!, @tophee! Thanks for that explanation.
